I am searching for someone that knows how to calibrate my oil temperature sensor on my ACS 2002, I know it's an older unit, but then so am I. I have calibrated other transducers over the years but the oil temp calibration is different. The reference to the "Calibration Display1 for the lower Data Point "
and the same for the upper data point, is where I get confused.
Additionally, there are no identifying numbers or letters on the unit that failed. It was on the XP 360 Superior engine kit, so I have not
been able to find the same sensor for it. The one that failed was a two wire shielded cable unit.
I have installed a new non-shielded two wire unit and it does change temperature but came with no instructions.
Thanks in advance,
LL
Thanks in advance,
LL
