I posted this query under a more obscure thread title but with no response, so thought I'd re-post with a more specific heading and perhaps clearer explanation of where I'm having problems.
There are 4 pins on the back of the DIN connector but only two wires to connect to it, the red and white WH-P325 power wire and the shielded white Data Out WH-F55 wire (I have the original D180 wiring, and this apparently becomes GRY/PRP WH-395 in the Skyview kit). According to the ACK instructions, the RS232-Rec wire, which I assume is the Data Out wire, goes to pin 4. Power goes to pin 1. Then a short 24 AWG test wire (which we have to make) is connected to pin 2.
However, the instruction in the manual which I don't understand (with punctuation as written) is:
3.) Connect one conductor to pin 3 and connect to aircraft ground at the cockpit. connect the outer shield to ground, at the cockpit end only.
My questions are:
1. Is WH-55/WH-395 Data Out to pin 4 correct, and what do I do with the exposed shield at the DIN plug end?
2. I assume it would be OK to use 22AWG wire instead of 24AWG for the test wire at pin 2 as I don't have any 24AWG?
3. What am I supposed to do at pin 3? What wire are they talking about?
Thanks in advance to those who have gone before.
My questions are:
