Moving right along in my-9 build.. after riveting the wing ribs to the rear spar, i noticed the bottom rib flange was not dimpled and the bottom of the rear spar (w-907-a)IS dimpled(not supposed be - I don’t think??). When i dimpled the tops, i went ahead and did the bottom to save time (this one bit me).
Question is…
Are they supposed to be dimpled or not?
If not, should i drill out every single rib/rear spar rivet just to un dimple? Should i order a new rear spar to be delivered with my Fuse next month?
or should i somehow dimple the spar flange to fit the rear spar dimples?
I’m so stumped, sad, and confused over this simple but major mess up and set back tonight.
Question is…
