asking for help again
Im dimpling the W822 access plates that go on the bottom wing skin. the instructions say the holes that line up with the spar flange use #6 screws and the others #8 screws it then says to dimple the plate to #6 screw. does that apply to only the holes over the spar flange ? and the rest you dimple to #8?
or do i just dimple all the holes in the access plate to #6?
thanks in advance
thanks in advance
