Accelerator pump, factory setting?
rjcthree
Having gone through the Ellison to MA4 challenge, when I had the MA4 core OH, it came back with the accelerator pump linkage set to the most volume. I get a modest but repeatable stumble when I roll into the throttle, seemingly right at 1500 rpm. It’s most notable when at 1200rpm in the pattern and having to roll into it to adjust. Like Paul’s video, in its current state, it will shoot fuel across the hanger. I’m curious as to where the the accelerator pumps are set from the factory? Next oil change I’ll probably take it to the middle hole, but for right now, I’m gathering data. I admit my idle circuit may be slightest bit lean, but boy are my plugs clean! ;)
otherwise, things are great.
