I am about to order my RV8 wing kit, is there any suggested changes or special orders I should make (I.e. fuel caps).
Also I may need to revamp my tools for the wings work. So what additional tools do I need for the wings that I may have not collected during empennage build? Shipping to my country cost a lot and it would be cheaper to buy all I need up front. My idea is to build the two wings together and use some extra hands by friends so it some redundant tools are good.
My current tools inventory:
1- Air Tools
Air drill, pneumatic squeezer, 3X rivet gun
2- Drill bits
#40 Drill Bits
#30 Drill Bits
#40 Reamer Bit
#30 Reamer Bit
#40, #30 12'' Bits
#21 #19 #12 #10
Unibit 1/8"-1/2" x 32nds
#6 Nut Plate Drill Jig
3- Riveter Squeezer Set
3/32" Cupped Set 3.5"
3/32" Dbl Offset Cup Rivet Set
1/8" Cupped Set 3.5"
1/8" Dbl Offset Cup Rivet Set
1/8" Thin Squeezer Cup Set
3/16" Cup Rivet Set 3.5"
1" Dia. Flush Set
#1 Flat Sqz. Set 1/8"x1/2"*
#2 Flat Sqz. Set 1/8"x3/8"
#8 Flat Sqz. Set 1/2"x3/8"
Back Rivet set
4- Countersink
Microstop Countersink Unit
#40 Countersink
#30 Countersink
#8 Screw*
#10 Screw
#6 Screw
5- Dimple Dies
Dimple Die Set for 3/32"
Dimple Die Set for 1/8"
3/32" Close Quarters Die Set
1/8" Close Quarters Die Set
#8 Screw DD set
6- Bucking Bars and Yokes
Back Rivet Plate
4" Yoke
3" Yoke
Clecos
Pliers (air and manual)
1/8" Cleco (125)
3/32" clecos (150)
3/16" clecos (10)
5/32" clecos (10)
1/2" Cleko Clamp (6)
1" Cleko Clamp (6)
Miscellaneous
Various edge deburr tools and wheels
Snipes
Edge Forming Tool
Fluting Pliers
Hand Seamer
1- Air Tools
2- Drill bits
#40 Drill Bits
#30 Drill Bits
#40 Reamer Bit
#30 Reamer Bit
#40, #30 12'' Bits
#21 #19 #12 #10
1" Dia. Flush Set
Back Rivet set
4- Countersink
#40 Countersink
#30 Countersink
#8 Screw*
#10 Screw
#6 Screw
5- Dimple Dies
#8 Screw DD set
Back Rivet Plate
4" Yoke
3" Yoke
Clecos
1/8" Cleco (125)
3/32" clecos (150)
3/16" clecos (10)
5/32" clecos (10)
1" Cleko Clamp (6)
Miscellaneous
Snipes
Edge Forming Tool
Fluting Pliers
Hand Seamer
