Smilin' Jack
With in a month I will move everything outside to put the wings on and set the angle of incidence on the wing. A couple of questions already
1. did you have your control sticks perfect before you put the wings on?
2. Is this a good time to do the horizontal and vertical stab also even if it is not the next item in sequence in the building manual
3. I also plan on doing my wing tips at this time since I have the lights installed already
4. Are the wings basically symetrical since I already have a dynon roll servo installed and can not put the rigging device on the right belcrank. Can I use two long boards and clamp the alierons in a netural position?
5. I have notice several RV's that when the alierons are neutral that either th e other side does not line up wit the tip or one is down and the other is up.. I assume that this is the time to get this all set even so every thing is in
Aignment. That is the reason for the question above.
I have read the forum about Zero and positive i wing incidence . Do it like Vans states?
I know this is long but thanks for your responses and suggestions.
Smilin jack
Smilin jack
