I started to configure the AP74 and all was well until prompted to push a/p disc. switch. The switch lights up when the strobes are turned on the way it should and pin placement was double checked. I was just wondering if others have had this occur? Thanks in advance
Thanks for the info. Jetguy. I found that I have a defective A/P Disconnect switch. For those who have not installed theirs yet, a simple continuity check will tell the tale. Van's said this is the first one they have heard about.
We had one too! We ended up buying a second switch, thinking it was the connection I put in the middle so that we could replace the center panel without problem. I afterwards tested it and discovered our switch was bad.
