Lionclaw
I bought the quart sized flamemaster brand sealant from Vans and I'd like to make sure everything is going the way it's supposed to. So far I've used it to seal the TE of the rudder and right elevator.
When I first opened the quart there was a brown piece of paper stuck to the top of the sealant. I had to peel it off, and it took a bit of sealant with it. The sealant is about the consistency of wet taffy - very thick and hard to stir.
I mixed it at 10:1 with the hardner using a digital scale and applied it to the trailing edges. I let it harden for a few days until it was no longer gooey before riveting the edges.
Even now, several weeks later, the sealant is still somewhat rubbery - perhaps the hardness of a pencil eraser. Is this right? Will it get any harder than this? Is it supposed to be this thick before applying?
