MSFT-1
I have owned an RV-10 for 3+ years and have flown it nearly 500 hours. I didn't build it. It is a great airplane and I have been enjoying it immensely.
Today, while I was on the ground, I noticed that the left aileron is deflected significantly more upward when I have the stick fully to the left compared to the right aileron deflection when the stick is against the right stop. I got out of the airplane and checked it more carefully and sure enough, the rivet line on the front edge of the left aileron disappears up under the trailing edge of the wing when fully deflected but when I deflect the right aileron upward that rivet line is still visible behind the trailing edge of the wing.
I just never noticed it before. Of course in normal flight I would never have a need to put the stick against the stop (in either direction). So the question:
Are all RV-10s like this, or is mine unusual? Should I be concerned?
BTW, the airplane flies fine with a little bit of the ball out of center to the right in cruise flight.
Thoughts?
Thoughts?
