grayforge
Hi Folks,
I'm pouring over the G3X (Touch) Install Manual Rev M and ran into a bit of confusion on a couple items.
On page 20-5, the diagram mentions that the CAN Node Length cannot exceed 1 meter. I'm not sure what is meant by this since the distance to the servos is certainly more than a meter. Does it actually mean that the length of the cable between the device and where it connects to the CAN Bus 'trunk' can only be a meter or less?
On page 20-9, the signal ground from the GTU 460 is shown going to pin 'NA' on the GTR 200. Does this mean signal ground is found elsewhere and pin 34 on the GDU 460 does not need to connect to the radio?
Thanks!
Russ
![CAN_BUS_Node_Length.jpg](/proxy.php?image=http%3A%2F%2Fwww.prettybits.com%2FlogImages%2F1%2FCAN_BUS_Node_Length.jpg&hash=c31d31b65089bcb533735a284a779aa0)
![GTR_200_Connection.jpg](/proxy.php?image=http%3A%2F%2Fwww.prettybits.com%2FlogImages%2F1%2FGTR_200_Connection.jpg&hash=b107dd5b08025ece2225c450bf0e059d)
Thanks!
Russ
