Flyguytki
So I have gotten into a really bad habit of not reading the instructions fully and just following the plans, well when it came to adding the stiffiner rings to the tank access holes, I just lined them up how they looked good and drilled away, no aligning the flat portion of the "Cap" to the stiffiner bead. One one of the Ribs I got Extremly Lucky and it lines us parrallel to the bead but the other is off pretty bad. I believe I have thought through all the issues that could arise from this and there are none that are major. However when it came to making an anti hang up bracket, this would not be straight up and down. I decided to continue on knowing that I may have to redo the entire piece but I thing It may work out alright, Do you see any issues with the Hang up bracket not being exactly perpendicular to the spar??
![IMG_8263.jpg](/proxy.php?image=http%3A%2F%2Fi286.photobucket.com%2Falbums%2Fll109%2Fflyguytki%2FIMG_8263.jpg&hash=69e8a711204b235b059e4f1a1a1dfc51)
