This is for all you QB wing 9A builders-
Was about to rivet my flap farings when I discovered I had not received any 426-3-3 rivets with my kit. I know the plans call for 3-3 rivets to attach the flap faring to the top skin. Anyone else have this problem? Van hasn't changed the rivet size has he?
Also--
With the QB wing which of course has the bottom skin riveted in place, it's kind of tough to get to some of the rivets that set the flap faring to the rear spar. I know it can be done by using the access plates and the lightening holes but I was wondering if anyone has used blind rivets for this part and if so what size?
BTW-don't need any smart remarks about how I should have done a slow build wing thank you.
Also--
