Lionclaw
I'm prepping my fuse parts for reassembly and I've got a couple questions:
1. Should I dimple the firewall flange and adjoining skins? If I don't do it now, I'll have to do them together later. If I do it now, would it be hard to match drill the hinges later?
2. The aluminum between the rivet holes and the main gear socket openings on the bottom skin is very narrow. Is it safe to dimple this, and should I be installing a rivet in each of these spots?
Thanks!
Thanks!
