Mark,
You'll have to work a bit to get them through the rubber grommets in the side of the fuselage. Put the line through the grommet first, then put the grommet into the fuselage hole (only overlaps one layer of skin). Using a flat screwdriver helps with getting the grommet properly seated on the skin.
cheers,
greg
