so after taking good care to align these W-932DG on the T-912 brackets, i have a problem with the one 3/16" hole that matches up with the hole in the wing spar. they are close, so very close but just off a bit.
i feel like i should have not drilled that one in the angle and marked it first, took it off and drilled that one, then back on to drill the remaining two.
i'm wondering if those AACQ blind rivets shifted ever so slightly when i fastened that bracket down.
anyone else have this sort of problem with those?
