Made a little mistake
and am considering solutions for a fix. Can't call Van's until Monday morning so here's the issue.
This is my 802B-L riveted to the 802F. I won't make excuses but I forgot to leave a hole open for the upper bolt that attaches the 802T (red rivet) and to countersink the 802F and dimple the 802B hole (green rivet). That hole gets a flush rivet because the 802T overlays that rivet a little bit.
Red rivet is no big deal. The hole for the bolt is larger so drill out the rivet and drill the larger hole for the bolt.
Green rivet choices:
1) order new parts and have a do over. Not a big deal except for the time to get the parts.
2) Trim the 135 degree corner of the 802T below the lower bolt hole about 1/16 to 3/32 to clear the rivet head. But the instructions specifically say the 802T should not be modified.
3) Drill out the green rivet and countersink the 802B (040 thick) for the 426-4 rivet. The depth of the 426-4 rivet head is about the same 040.
I don't want to drill out all the rivets so I could dimple the 802B and countersink the 802F as I think the overall structure will be weaker doing that.
I'm leaning toward option 3. Even after countersinking the 040 thick 802B the 426-4 head will be almost completely supported by the 040 material. Not ideal though.
Thanks for any input.
![IMG_1317.jpg](/proxy.php?image=http%3A%2F%2Fi454.photobucket.com%2Falbums%2Fqq264%2Fskybobby%2FRV-8%2FIMG_1317.jpg&hash=6b6ee8d11b722223f0475f11fb437df8)
