Morning All-
I'm Getting some differing opinions on this topic and wanted to see what the gereral VAF community opinion is.
Heres the deal. I’ve been avoiding countersinking the main spar for the #8 Tank attach screws till I had some primer mixed up to spot prime. I’m a little confused as to the depth of these counter sinks. Normally, they’d be cut to accept the skin dimple. But the excerpt from the plans (below) makes this sound like they should match a #8 screw head (flush to the spar flange) and not the dimple. What is the proper proceedure here?
"Machine countersink (trying to dimple the 0.063 thick spar flange will result in severe distortion!) the platenut attach holes in the W-706A spar flange. See Section 5E. Use a microstop countersink with a #30 pilot to countersink the (screw holes in the spar to the proper depth for the #8 screw. The pilot will center in the countersunk platenut well enough to keep the hole round and concentric. (Tip: cut a #8 screw short so that it enters the K1100 nutplate easily and use it to gage the depth.)"
Thanks All!
Thanks All!
