flyingbeaver26
Active Member
I'm ready to order my FWF kit. I have a some concerns that there may be a couple items I need to omit from my order based on my set up. I have built a custom throttle quadrant, so I believe the stack throttle, mixture, & pitch cables will be too short. Not positive though. Here is what I already have:
- Lyc IO360 M1B
- Hartzell blended prop
This is what I plan to buy at the same time as my FWF kit:
- Raven Inverted oil
- 1 LS ignition plasma II (replace 1 mag)
- Vans FWF kit for IO360 M1B (sans engine control cables)
- MT prop governor
- Vetterman exhaust (2-pipe exit)
- Heat muff for exhaust
- Sam James Cowl
- Sam James Plenum
Based on my shopping list, is there anything that comes to mind that I should add or subtract to my FWF kit? any other general advice is appreciated too regarding my set-up.
Brad
- Lyc IO360 M1B
- MT prop governor
- Sam James Cowl
- Sam James Plenum
Brad
