Couple of questions on the flaps...
the FL-406A,B,C reinforcements - are there any specific dimensions for these anywhere except what is buried in some of the drawings? It is difficult to pull out the dimensions with all of the other measurements.
Also, is FL-406B (the plate) in the kit (can't find it on the list) or is it to be fabricated from the 0.125 sheet (AS3-125x4x12). I hate to cut the sheet if it is needed for something else...
The -8 flaps are significantly different (at least in this area) than those on the -7 web sites I've seen.
Thomas
-8 flaps (allegedly the "easiest control surface to build
Thomas
