tx_jayhawk
I'm installing the steps in a 7A QB, and I was looking for some helpful tips. How have people been drilling the 1.5 inch hole on the inner rib? The SB 7A has you drill it prior to installing, as you can't get an angle drill in there after its installed in the QB. I don't see how a dremel can get in there real well either.
Also, any tips on bending the flange? I plan to cut/round the corner, but it appears the whole assembly needs shaped somewhat.
Thanks for any help. There is one similar post on this, but the method described was not clear to me.
Scott
7A Fuse
Scott
7A Fuse
