Paul K
OK, Van's builder support is closed and I would like to continue with the engine mount installation early tomorrow so here goes:
My firewall mounting holes line up really good, no pushing required, all four holes near center. The problem is that the QB firewall arrived with a fuel pump doubler and platenuts installed down near the lower crossbar by the front gear mount. One platenut is in the way of the engine mount and holds it about 1/8 of an inch away from the firewall. What to do? Options:
1. drill out the doubler and replace it with a new doubler without the platenuts?
2. just drill out the platenuts and fill the holes with firestop?
3. grind the platenut down and cover it with firestop?
4. something I haven't thought of yet?
I am not going to use these for a fuel pump so I don't think they serve any purpose.
Another thing I don't like is the 1 inch hole in the firewall to install the front gear bolt. Any ideas?
