Jekyll
Agreed. You will have to remove some of the flange in that small area. Below is mine from the outside, sorry no pic from the inside.
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The steel socket weldment now covers the cut away. I used a Dremmel tool with a HHS "milling" tool -- my term) to remove the annodized material and skin to very near the edge of the rivet shown above socket. I, too, thought it excessive at first, but after thinking more about it, the construcion of the steel socket weldment and the way it is installed with all the bolts makes the area SUPER strong even though some of the aluminum was cut away. Just do it, but go slowly while you "cut and try" It took me a couple of hours on each side before I was satisfied.
You want to leave a little space around the gear socket (through the skin)to allow for the radius of the weld, too. I have seen some RVs with the gap, about 1/16", filled with silicone or Proseal to keep moisture and dust from getting in the cabin area from outside.
On my QB Ifound it just a little difficult to slip the gear weldment socket into place because it bound on a bolt in the center section, but with a little force by hand and a tap with a plastic mallet, it popped into place so I could bolt it on.
CAUTION: Ream or drill the bolt holes to get the powder coat out of the weldment bolt holes BEFORE installing it.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It saves some frustration. I also had a slight misalignment of weldment bolt holes with the center section holes, but a little bit of round filing took care of that problem.
This is m first post of a pic, so I hope it does as I expect...
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
If not, I can send it via regular email if you send your address to me.
[email protected] Let me know if you want more.... Glad to help you out!
Don Gray
Cortland, OH
N17QB
