I'm at the point I need to make an engine decision. In doing the research, the majority of 7As are in the 79 and 80" CG range. CG can be a little tight at heavier weights after a long flight.
One option is to use the James "Long" cowl, IO360 and the Hartzell BA M2YR-1BF/F7497. The 40-50 lbs, moved forward the 3-4" required for long cowl would seem to help by moving the BEW CG forward.
Does anyone have this combination installed? Can you share your CG station along with your BEW? Any other thoughts or am I just hoping for a low cost CG solution when in fact it doesn't exist?
