frankh
Morning all,
Just did the fianl rigging of the ailerons only to find the rod ends only screw in about 5/16th inch on all four rod ends.
My sticks are vertical and I set the neutral point of the ailerons and the belcrank with the template guage on the spar.
I pulled one tube out of the wing and measured it and its exactly the length shown in the drawings..
Anyone else seen this and what did you do about it?
Current thoughts are 1) buy 2 longer rod end bearing, one for each rod.
2) machine up an insert that fits inside the big tube, cut the tube in half and use the insert to extend the length of the tube.
I like #2 cus I can do it without ordering more stuff and waiting for it.
Thanks for your thoughts.
Frank
Frank
