I was crackin up just reading it. I had to find that clip... http://www.youtube.com/watch?v=jMCquiLQ96IDeltaRomeo said:Dan's referencing Spinal Tap. Man I love that movie.
DeltaRomeo said:Yo Dan!
OK, the -7 I have flown (about 30 hours in it) is MUCH less pitch sensitive than my -6 in the flare and it floats more down the runway (longer wing).
My -6 seems to require more attention while landing...well maybe that's not worded right....it's just more 'twitchy' (which I like actually).
This help?
The -6 and -7 horizontal and elevators are essentially the same (other than skin thickness on the elevator). The -7 has a longer fuselage, which has to help in the pitch stability dept.az_gila said:OK.. so has anyone put the larger straight horizontal/elevator on a -6 to see if it gets less sensitive....
It would be hard to make the -6 wing bigger, but relatively easy to increase the tail area with a -7 tail.
With all of the 6's out there, I would think someone has done this change...![]()
dan said:The -6 and -7 horizontal and elevators are essentially the same (other than skin thickness on the elevator). The -7 has a longer fuselage, which has to help in the pitch stability dept.
dan said:I doubt you're missing anything, but if what you're saying is true (and I assume it is), then the effect is basically like pushing the average engine/prop on any given RV-6 a full 2" forward of where it is now. That must have a CG-related stabilizing effect, right?
Scott's -7 has thinner cushions so my head room is massive compared to my -6. I usually throw an extra cushion in to see out <g>.Captain Avgas said:Doug, I have flown in 6s and 7s and found the head room to be better in the 7. But this could have been due to different seat thicknesses so I'm not sure.
What did you find.
The -7A's larger rudder (especially the newer -9 style with the even larger counterweight arm) would account for some of that extra height.Jamie said:Yes, I believe that the gear leg geometry is different on the -7A vs. the -6A. Van's lists the height of the -7A at 7 foot, 10 inches while the -6A is listed at 6 foot, 8 inches.
Look at pictures of 6As...they sit tail low whereas the -7As and -9As sit almost perfectly level.
RV7Guy said:I understand the seat pan area was lowered 2" on the 7 to provide more head room.
I understand this too, but 1" not 2". On my 6 I raised the roll bar 3/4 inch for more headroom, and I can tell you 1" makes a significant difference.RV7Guy said:I understand the seat pan area was lowered 2" on the 7 to provide more head room.
That doesn't make a whole lot of sense, the arm from the Center of lift to the engine would have to be shorter on the -7 or from the Center of lift to the HS would have to be longer to account for the ability to handle the heavier engines. Perhaps the moved the wing forward a tad on the 2" longer fuse? Anyway...az_gila said:thanks Dan... I got mixed up on the straight horizontal models....![]()
But... Vans web site has the -7 as only 2 inches longer, and I thought this was in the area in front of the instrument panel.
Am I missing something here?? Is it really longer from the trailing edge of the wing to the elevator hinges?
gil in Tucson
