I've got two questions regarding fit of these fairings. I haven't found answers in the archives.
1. Seems like I'll have to cut a hole in the upper intersection fairings to accommodate the hose clamps . Is there a better way?
2.
With weight on the gear, the leg fairing is flexed causing a gap at the underside. This seems to stop the lower intersection fitting well. If I jack it up to fit the intersection fairing, the leg fairing will put pressure on it when on the ground. Is this acceptable?
2.
