alpinelakespilot2000
Just beginning the serious bending on the slider canopy frame. Manual says side rails of frame should parallel fuselage side skin but be inset 1/16". However, the manual also says that the builder needs to "subtract 1/2" at the front bow to compensate for the spreading of the frame caused by attaching the Plexiglas canopy." The two seem to contradict each other.
Should I read this to mean that I first align the side rails to 1/16" and then, from that point on, disregard that 1/16" distance and reduce the size of the front bow by another 1/2"? (The instructions for the aft bow seem to imply doing the same but by 3/8" instead of the 1/2" for the front) By the time I'm done then (but before I mount the plexi), the side rails will be much farther from the side skin, both at the front and at the back, than the original 1/16"?
Any help visualizing what I'm supposed to be doing here, and in what order, would really by much appreciated. (I've read through all the canopy threads I can find and still don't feel much more comfortable with it.)
Thanks.
Thanks.
