While flying my new-to-me 9A my flaps stopped working. After examination I discovered the flap actuator had become disconnected from the flap weldment arm. Seems like a somewhat easy fix but I have questions:
1) While disconnected from the flap weldment arm the flap actuator rotates under power, is this normal?
2) It appears the builder drilled through the actuator and into the jam-nut bolt in a failed attempt to drill a hole for the safety wire. He then successfully drilled another hole through the actuator for the safety wire. (see attached pic link).
3) The jam-nut has a hole in the end, is that for grease? Or do I simply apply grease to the swivel on the jam-nut?
4) Assuming the rotation of the arm is normal and will stop when the jam-nut is tightened are the arm and jam-nut okay to use as is? (see pic link)
