gerrychuck
I've read a great deal on here with regard to nose wheel shimmy, bearing preload, breakout force, etc, etc. I now have 12 hrs and 17 takeoffs and landings on my 6A, and have experienced completely shimmy-free rollouts, slight shimmy on braking, and major paint-mixers where the shimmy seemed completely unrelated to speed; it was just there as soon as I touched the brakes, and continued whether I stayed on the brakes or lifted right off. I have come up with a couple of observations, though, and wondered if others have noticed the same things.
First and foremost, I find that the shimmy I get is directly related to how I land the plane; if I hold the plane off with the nose way up in the air for a full stall touchdown, I will usually end up with a lot of shimmy on the rollout, not to mention not being able to see squat in the flare. I am thinking this is because with a full stall touchdown you can't hold the nose wheel off and it comes down fairly firmly. On the other hand, if I flare low and touch down a little faster with the nose a wee bit lower, I am able to touch down more smoothly, hold the nose wheel off longer, get better aerodynamic braking, and usually get no shimmy, even when I do get on the brakes. In both instances, I always retract the flaps before applying any brake.
For me, the landing technique seems to be the main determining factor, more important than tire pressures, etc. I did a rough check of my bearing preload and breakout force this week; I think the preload is pretty close, and the breakout force might be a bit low (I'll check with a calibrated force gauge one of these days) but the fact remains that if I land with the technique noted above, there is no shimmy.
Does this jibe with what others have found? Just curious and interested in others' experiences and observations.
Gerry
Gerry
