ChiefPilot
So today I fit one of the wings to my -6A project and was dismayed to find that the gear weldments provided by Van's are apparently not drilled correctly. The holes for the bolts that hold the weldments to the fuselage sides match up with the fuselage ok, but the holes that are supposed to match up with the wing spar are all off by almost 1/2".
The only fixes I can think of involve drilling new holes after either obtaining new weldments or having the holes in the existing ones welded closed. Either way, it looks like undoing a lot of progress (removing the tail, control column, etc. and flipping the fuselage, then removing the bottom skin. I don't see how I can match drill the holes to the spar any other way - there just isn't enough clearance for a drill between the bottom row of holes in the spar and the bottom skin. On top of that, it seems like I'd need to set the gear angle this way as well.
I've already e-mail Van's on this, but given their turnaround time I'm hoping to get some ideas (and perhaps encouragement here....
Thanks!
Thanks!
