paulsteger
I'm New Here
I have a 6A that I did not build. The top and bottom cowlings are held together by two long, horizontal hinge pins that each have a drilled tab at the end to secure to the cowling front. What welding/ brazing process should I use to replace a tab that whose pin broke off just as it enters the tab, which I believe is stainless? Drawing just says to weld it. Original looked like it was soldered,though I don’t think that works with stainless.
