for those of you 6A or 7A drivers who have run hoses from the wing roots to the brake calipers instead of the spec'ed soft aluminum tube, I have a few questions:
- what size hose did you use and what fittings did you use on each end (3 or 4, straight or 90)
- did you leave a loop in the hoses before the calipers, similar to the one used with the aluminum tubes?
- how did you route the hose down the gear leg, in front or behind the leg? (would it matter?)
thanks in advance for your answers (assuming there are some ...)
