Hi folks,
I'm building the VS spar and have predrilled the rivet holes in the VS411 brackets, the outer holes being to the nominal 1/4 inch edge spacing suggested.
However, I've now located the brackets on the spar (VS403) and doubler plate (VS408) and found if I carry the outer holes through the doubler plate the edge clearance will be only about half that required.
Ideas I have had are to contact vans (awaiting reply), make new brackets as it'll be quicker than getting vans to send them to me in new zealand, or to place two extra rivets in the spaces between the three specified (which may be a silly idea?). I should add I am happy to make new brackets, but if there's another sensible alternative I'd like to know.
Any further thoughts?
