Since starting my build back in 2015, I now have 3 kiddos (7yo and 2 3.5yo twins). I've been reading up on various approaches to getting a fifth seat in the back of the RV-10, and wanted to poll the community, ideally from anyone who's done this mod, for advice on the best approach and on how it's worked. Research below, with questions in bold inline.
1. Add another attachment to the longeron on one side, run it to the middle. Slightly offset. I can't find my reference for this anymore.
2. "I just added a connector bar between the existing cables in the luggage area and added the third harness in the middle.", from https://vansairforce.net/threads/5-seat-rv-10.199492/post-1558279, via @AaronG
3. add a new attachment point to the canopy, from @ReidVaitor https://vansairforce.net/threads/5-seat-rv-10.199492/post-1558071:
> As for your seat belt question, add another shoulder harness in the center, basically drill a 2-3" hole in the center canopy fill it with the thick fiberglass cloth (used for doors) than 4 ply of glass about 5 inches wide under it. plenty strong enough then add the center shoulder belt.
Thanks all!
Seating / Cushions
The old answer was "Classic Aero" for the bench seat, but I don't see the RV-10 listed anymore: https://www.classicaero.com/web/public/cc/CC3.php?G=3679BCC14E684B31A97F0CE8C5A90865. Has anyone had success with a filler cushion, or a 60/40? I've already got the rear seats from Aerosport, it'd be great to add on to these, but I'm also fine swapping out the seats if I need to to switch between 4 and 5 seat arrangements.Lower attach points
The lap belt attachment makes sense, just use the existing attach points with longer bolts. Do folks do a fifth point for the middle seat, or stick with shoulder and lap?Shoulder harness attach
I've been reading up on various approaches to adding the shoulder harness attachment, and I see three different ideas. What do folks think is best?1. Add another attachment to the longeron on one side, run it to the middle. Slightly offset. I can't find my reference for this anymore.
Thanks all!
