47-03 Prop Bolts
KRAUSEGB
Do I read Fig-2 correct?
Should I install nord-lock washers under the bolt head as well as the lock nuts when attaching the hub mount half to the prop shaft?? It's not clear in the figure but I was supplied enough to do the job.
Gary
That is correct. Just make sure you put the right Nordlock sides together to lock them. When you loosen them to change your pitch you will hear a "click" as the Nordlocks pop loose.
Pete
