I really like the angled oil filter adapters that I have gotten on my engines from Mattituck (don't know what part they use, but Mahlon Russell should). The B&C unit is very nice. I have used it and like it. They will know what spacer you need for the -10, if any, with information on what other parts you have on the accessory case.
The filter straight out the back is a pain, but it works. There is a technique to changing the oil without spilling, but it can be done. It's easier with the angled adapter by punching a hole in the filter when hot and letting the oil drain out over a few hours. With the horizontal filter, a little compressed air gently blown in the hole can evacuate most of the oil, with a Walmart bag catching the rest as you spin it off.
If money is no object, then get it. If you are pinching pennies, skip it. If you are in between, maybe wait and see.
