Cardinal_Biggles
I'm New Here
Im looking at wiring a collins CDI up to a garmin 430. The install manaul for the garmin says i need shieded pairs from the 430 to the CDI (probably physically located about 2 feet of wire length away). The collins install manual only has a collins nav reviever / cdi hook up and does not use shields. Im a bit of a novice and want to do the job correctly so looking for practicle advice on how this should be configured or what an avionics shop would likely do.
