Out of interest, what do you clean them with?..I see harbor freight have spark plug cleaning shot blaster thing but I have no idea if it works as it should?
Frank
400 hours on stock Lycoming plugs. I clean and rotate them every 50 hours and every time there are considerable lead deposits on bottom ones.
Vlad, you are coming up on a good time to consider replacing a mag with a PMag. I did this before Sun-n-fun and it has been great... pretty much eliminated lead build up on my mag plugs. This year on the trip I burned 31 gallons less than last year on similar 6,800 mile trips.
I too have been using Champion Iridium fine wire plugs for 750 hours and 10 years of flying with no problems. However, having said that, I am curious as to whether the Tempest plug "gouge" about competitor plugs not perfoming to spec once the resistence goes above 5K ohms has any merit. I checked my plugs at the last oil change and found some up them higher than my ohm meter's scale. The lowest reading I got was 14K and the highest was 125K. The plugs "seem" to perform well - but I am wondering if I bought a new set of Tempest's if the engine would run better. OBTW - I did check a new Tempest plug the other day, and it's initial resistence was 1.4K ohms, well within their "new" resistence allowance of 1.5 - 3 K ohms.
Anybody have any thoughts or history?
Thx
