Good Catch, weight correction
Steve Sampson said:
George - like for like I doubt the weight difference you have there. I don't understand the source you are quoting. The only difference between an XP-320 and XP-360 except for the crank (which presumably has a negligible weight difference) is the 4 cylinders. They are slightly larger on the 360 and that I think accounts for 11lbs in total that you cant get away from. I was given that number by an engine builder in the UK.
Cheers.
Yea Steve good call I used a IO-360-A, C (200 hp) weight. Here is my source.
Look at O-320-B, D (255 lb) and IO-320-B, C (259 lb)
http://www.lycoming.textron.com/main.jsp?bodyPage=/productSales/engineSelectionGuide/320.html
Look at O-360-A (265 lb) IO-360-B (270 lb)
http://www.lycoming.textron.com/main.jsp?bodyPage=productSales/engineSelectionGuide/360.html
So the weight diff is about ** 11 lbs as you say according to the links above. So I stand corrected, thanks.
However word of caution that many of the 360 clones weight more in general than the Lyc equiv like the O-360-A, which is a light weight engine. May be Mahlon or someone can chime in but the clones are a bit heavier especially the Superior XP-360, which I believe uses a counter weighted crankshaft.
Superior list their XP-360 weight as 290 lbs / 287 lbs (FI/Carb). That is about 20 lbs more than the listed Lyc dry weights. I don't believe anyone uses counterweight cranks on 320's so my original weight I posted of a little over 290 lbs is about right for a XP-360.
Bottom line these are all estimates and you don't know until you put it all on a scale. Of course these are dry weights.
** My "research"
(ref.1) of over 100 actual finished empty weights of
flying RV's shows that 320 RV's weigh at least 20-36 lbs less than RV's with 360's. Here's an excerpt.
EMPTY WEIGHT BY PROP, ENG or ENG/PROP
Total; Eng/Prop; MIN; MAX; AVG
60; FIX;..........874; 1170; 1041
55; CS;.........1010; 1244; 1111
41; 320;..........874; 1168; 1034
60; 360;..........986; 1189; 1084
14; IO360;.....1103; 1244; 1151
32; 320/Fix;......874; 1106; 1019
28; 360/Fix;.....986; 1170; 1066
09; 320/CS;....1010; 1168; 1084
32; 360/CS;....1026; 1189; 1101
14; IO360/CS;.1103; 1244; 1151
Fix or CS = no breakdown of brand, blade material, most popular: Sensenich & Hartzell
320 = 150 or 160HP Carb or injected
360 = 180 HP Carb or Injected
IO360 = (200HP)
Of course doing statistical analysis and trying to filter out all the variables is not easy with the info available. The prop was fairly straight forward to factor in, since that is usually reported; however paint, upholstery, panel and so on is harder to do. Clearly there are 320 RV's that weigh more than 360 RV's, but by in large equivalent 320 powered RV's are lighter, for the obvious reason of engine weight.
I think a good safe number for the 320 Vs. 360 weight delta range is 18-50 lbs. The builder has to be careful with every ounce they put on their plane. Why do the 360 powered RV's weight more than the 11 lbs dry assy weight Lyc post? Probably heavier accessories: prop bolts, oil cooler, air filter and so on. It all adds up.
(ref. 1)
http://www.vansairforce.com/community/showpost.php?p=784&postcount=19
