32-11-2
KRAUSEGB
I AM HAVING A PROBLEM WITH ATTACHING THE CUSHION CLAPS FOR THE RUDDER CABLE TUBING GUIDES.
SEC 32-11 STEP 2 FIG.1 SHOW THE MOST FORWARD CLAP USING THE SAME HOLE THAT I USED FOR THE GROUND WIRE CONNECTION.(SEC 31-11 STEP 7 & 8) I AM SEEING SOMETHING WRONG OR SHOULD I DRILL A SEPARATE HOLE FOR THE WIRE TERMINAL GROUNDS?
GARY
Hey Gary
The directions were not exactly clear at that point. Use the same holes and stack them up. Several good ideas on how to get the clamps to work easier have been covered. Best seems to be using safety wire to hold the clamp together as you put it on the bolt. Cut the wire when done.
John Bender
