rapid_ascent
I've been working on my electrical design lately. My plan is to have a 30A Endurance Bus which will be driven by my standby alternator in the case of primary alternator failure. So to that goal I've been targeting higher priority devices to be on that bus. I realize the normal load will be much lower and I also realize that others may feel that they can fly on much less than what I have on my list. In my case I would expect that to be the case only if I lose both alternators. In that unlikely event I can switch off or pull breakers to leave only the most critical devices.
Given this scenario I've listed what I plan as of right now to put on my endurance bus. I'm hoping for feedback my list in case I left anything out that I should include.
Aux. Alternator
GDU-460 (PFD)
Mini-X (Backup PFD)
GSU 25 ( Primary ADHRS)
GSU 25 ( Secondary ADHRS)
GEA 24 (Engine Instruments)
GMU 11 (Magnetometer)
GNS430W (Main)
GNS430W (COM Tx)
GTX-335w/GPS (Transponder)
Boost Pump
Aux. Alternator Voltage Regulator
GAD 27 (Main) /GT-50 Backlight
Flaps Motor
GAD 27 (Roll Trim)
GAD 27 (Pitch Trim)
Aux. Alternator
GDU-460 (PFD)
Mini-X (Backup PFD)
GNS430W (Main)
GNS430W (COM Tx)
Boost Pump
Flaps Motor
GAD 27 (Roll Trim)
GAD 27 (Pitch Trim)
