aeroaddict
Thought I would try a 2X gun. At pressures for 20 psi to 90 psi, gun will only cycle for 1 to 1.5 seconds. Then I have to release the trigger and pull trigger again. First try was on a #3 rivet but then I put the gun on the bench top to figure out the cycling. Again, at 10 psi intervals, gun would only hit/cycle for about a second.
Am I doing something wrong?
