Good weekend everyone,
I've been hooking up my avionics and making sure they all talk nicely to each other and I noticed that my GRT HX is reporting 1 volt less than all of the other avionics capable of displaying input voltage. My GRT HS shows 11.x volts but the GRT HX shows 10.x when running off battery power.
Before I go tearing into my wiring loom (my avionics were wired by Aerotronics a few years ago), is it correct to assume this is probably due to a bad splice in power wire feeding the HX?
