What radio? Intercom? Audio panel?
I am interested in adding a comm radio and want to know how to wire it up without paying big $$$ for an audio panel. Any help would be appreciated.
lhawkins RV4 flying 655 hrs RV-3 building fuse
As other mentioned the Garmin SL30 and SL40 is a true two receiver in one radio, that does not need an audio panel or second antenna. The new ICOM that has "traffic watch" is a joke. Its really a scanner that goes back and forth between two freqs but never at the same time. In other words it has one reciver.
If you go with DUAL radios, for sure you will for sure need a second antenna. FORGET any kind of antenna switcher manual or auto switching, forget it. TWO RADIOS, TWO ANTENNAS. To not have a second antenna really makes having two Transceivers null and void. Again the Garmin does not need two antennas. It's a pricey little devil but worth it for this little two receiver, one transmitter integration deal.
The wiring. Not a problem you will need a switch to select which radio the PTT switch will KEY. That is easy, a simple toggle double pole, single throw DPST switch will do. Just put a label on it "TX select" COM #1 and #2.
As far as audio you can do that with out an audio panel. All you have to do is turn up or down the volume as you desire. Now you want to make sure you are not transmitting on the radio that the volume is down on. That is where an "audio panel" comes in with basic logic. It know if you want to TX on radio #1 you want to listen.
How do you mix two radio audio? Easy but need to know what you have now. For some radios like ICOMS A200 you can just feed the second COM into the AUX input of the ICOM.
If you don't have a COM with AUX inputs you can make a little hidden fixed (adjustable) mixing circuit behind the panel.
The next step is an audio panel. The problem with audio panels is overkill for a homebuilt with two Coms. Audio panels often have COM 1 & 2, NAV 1 & 2, ADF, DME, MB........
New audio panels are expensive new. Old audio panels off of eBay might work, King, Narco & Terra. The latter two have thin profile versions that can be had for a few bills. If they are not beat up they look OK. You can even make a "DIY" RST audio panel.
PS engineering make a very simple intercom with selector buttons for COM and NAV 1 & 2 in a no nonsense design. It's not cheap but integrates all the functions.
