How about right beside the main battery in the tail cone!
The CofG needs all the help it can get!
DB
Or two 6 AH batteries wired in series:
http://nerv10.com/wcurtis/90Electrical/EL1k.html
Idea from Tim O.
http://www.myrv10.com/N104CD/fuselage/20050821/RV200508200024.html
Not if you put 2 on the left side and 2 on the right side. You get 12 ah @ 12 v.To get the 12ah the OP wanted, (assuming 12v) the batteries would need to be 12v, and wired parallel to get 12 ah.
I don't have a W&B on my plane yet, but it looks to me that if you have 2 older gents infront at 220lbs and 2 trophy wifes in the back at 110lbs and 100 lbs of shopping (to keep the trophy wifes happy), that it gets close to aft CG. Might need a little wiggle room on the wifes. I thought I would like to put the battery up front.
Two batteries in series will give twice the voltage, and same amp hour.
In your photos, I assume you are using 6v batteries?? This would give you 12v and 6ah as shown.
