28-02 Step 1
Gandalf
I used the 75 inch/pound setting used for 3/8 inch fuel lines when attaching the AN816-6-2D to the fuel pump. Seemed like a lot of torque. Is this correct?
Also, I read somewhere that I should run the ground terminal from the fuel pump through the AN4-4A bolt. Is that correct? Also I ran the terminal under the washer so that the bolt head is on the washer.
Jeff
