I think you have that the wrong way round. A 6G load test would have a load applied to the top of the wing, bags of sand or cement. A negative G load test would mean flipping the aircraft and placing a load on the underside of the wing. Also the load isn't uniformly distributed along the wing. The wing root takes much more of the load than the tip. On your RV-7 the wing tip itself is part of the lift producing structure, but its unable to carry much loading. If you start applying loads to this area then you will likely break something.I recently purchased an RV-7A that has an airworthiness certificate which includes the usual charachteristics, such as Vso, Vx, Vy, weight, and CG. The builder did not certify it for aerobatic manuevers. I didn't build the plane, but it's been flying for several years and been through a decade of condition inspections and pre-buys. However, that doesn't tell me anything about its aerobatic manuever capability. At some point, I'd like to get training and eventually be able to fly appropriately-rated aerobatics this airplane.
I understand I can contact a FSDO to arrange a test flight to demonstrate aerobatic manuevers, but I'm a little hesitant to do so without doing some ground load testing of the structure first.
I haven't seen this mentioned anywhere before, so please let me know if this exists somewhere that I've not yet seen. But what I would like to do is conduct some ground load testing on relevant surfaces and structures prior to testing in the air. The last place I want to learn about an insufficient load capability of an aircraft structure is in-flight.
With all that being said, is there a way to test structural loading on the ground prior to an aerobatic flight test?
I'm thinking if you're a structural engineer, you ought to be able to determine the rated loads based on G-rating and then apply a static load to those structures to verify the rating. Shooting from the hip, I'm envisioning anchoring the gears to the ground and applying a uniformly distributed load to the underside of the wings and the top side of the horizontal stabilizers simultaneously to whatever the equivalent of 6Gs would be. Then to confirm 3G negative loading, apply a uniform load to the top side of the wings and bottom of the horizontal stabilizier.
I'm just spitballing here to start a conversation. Let's discuss...
No, you're right! I miss-read your post, and managed to confuse myself (which isn't hard!) my apologies.I'm not a super seasoned pilot, so I aplogize if I got things backward. I'm just trying to think through this... If the aircraft is straight and level, and you pulled back on the stick, I'm assumig that would be a positive G manuever, causing the plane to pitch up. For the plane to pitch up, I'd imagine the underside of the wings would see increased loading in order to produce more lift. If we assume, as you suggested, that the top side of the wings would get more load in a positive-G scenario, wouldn't that cause the plane to pitch downward, producing negative G loading?
The reason for wanting to do this test is explained in my OP.
It’s even harder if you are testing without any instrumentation like applied strain gauges in strategic points based on your analysis of where elastic/plastic deformation can/could occur and what you will do with said data once collected. It’s not necessarily as easy as load the wings and see if they hold. That’s half the way to the actual answer. Hence why engineering has already been done. What is needed is verification of the build to plans. Everything else is retesting something that’s already a proven design within the performance limits of the aircraft.Some assumptions can be insidious harbingers of unintended consequences...
Jjackh10 is right in that we shouldn't assume the landing gear and the way they attach are capable of managing loads opposite to how they are designed to work. Maybe yes, maybe no, but not a good place to assume. I once redesigned how a mast stepped into a large sailboat which is a fairly simple compression load. When I got around to testing that structure it became clear that I couldn't be sure my tests were going to prove my design apart from the actual in-service evaluation.
It's a noble effort to be sure, just really hard to do in a way that is going to give you meaningful metrics. For example: if done properly you will observe X amount of elastic deformation in the applied force vector and Y amount of ancillary deformation in downstream skins as a result of unmanaged compression loads. So how much is too much?
Best case is maybe to repeat exactly what Van's did and see if your displacements are close to what they observed?
Another good point. If you plastically deform the aircraft when testing, your plane is done until you do major repairs to fix the damage.Yeah, I get that it was built in somebodies garage, but realistically, this idea is no different than saying that you want to do compression load testing on a 172 or Bonanza wing to confirm what Cessna/Beechcraft is telling you.
Production airplanes load test with test articles, then build real airplanes to match. It's not like Cessna is piling sandbags on the wing of every 172 that comes out the door.
If it was built to plan, it will do what it' supposed to do. if it wasn't built to plan, it may or may not. Far better to confirm the build quality than potentially wreck it by load testing.
This is a really strong point. It sparks the question whether Van's considered the material that underwent their testing to still be airworthy. That said when load testing structures to validate design stiffness we don't need to go to the limits. I would only go to a limit on the way to an intentional discovery of ultimate load (breaking it which you want to avoid). Since our artificial loads won't match actual use loading it wouldn't be prudent to apply a full design load. Better to validate at some fraction but again you have to have the expected metrics in hand before you get underway. If Van's had been using strain gauges, then that would be a part of finding that sought after repeatability or something that shows you a deviation (weakness).Im not sure I would want to get in an aircraft if I thought someone had done this sort of testing to it.
Depends on the desired level of testing. Testing to yield or failure is destructive so yea, don't fly it. The OP seemed to just want to validate design limits. So properly loading the airframe with weights to +6g and -3g on the ground would be no different than doing it with flight testing. It would only be destructive if the assembly was incorrect, thus failing the testing. Certainly a safer way to test than in the sky.Im not sure I would want to get in an aircraft if I thought someone had done this sort of testing to it.
Going up to the design limit is not being careless it is max performing the plane. It has a safety factor built in as with any engineering design. Should you go above the limit? No. Could you accidentally over G or over speed? Yes. There are consequences if you exceed the limit of course. Either way going up to but not exceeding a limit is completely safe if done intentionally.Depends on the desired level of testing. Testing to yield or failure is destructive so yea, don't fly it. The OP seemed to just want to validate design limits. So properly loading the airframe with weights to +6g and -3g on the ground would be no different than doing it with flight testing. It would only be destructive if the assembly was incorrect, thus failing the testing. Certainly a safer way to test than in the sky.
I'm certain many RV builders set their OP limits as Vans recommends without full testing. Actually pulling +6 -3, gross weight testing at cg extremes, fly up to VNE, etc. That seems a bit careless or maybe arrogant to me. They're assuming they assembled the airplane perfectly according to design, despite the many examples of mistakes posted here and other places. I know I screw up occasionally, so if/ when I build I intend to test fully. I enjoy jumping out of airplanes so I will do it in the air hahaha.
I'm sorry, maybe I didn't word that right. I agree, I was suggesting NOT testing to design limits could be viewed as careless. Careless maybe isn't really the right word either. Maybe just less than through? My view is that testing to those limits would validate that the builder hasn't made a mistake or deviation that erodes an engineered safety factor.Going up to the design limit is not being careless it is max performing the plane. It has a safety factor built in as with any engineering design. Should you go above the limit? No. Could you accidentally over G or over speed? Yes. There are consequences if you exceed the limit of course. Either way going up to but not exceeding a limit is completely safe if done intentionally.
How so? What if a builder error had cut the margin to 10%, or 5%, or 2%............what happens then to the engineered safety margin?I'm sorry, maybe I didn't word that right. I agree, I was suggesting NOT testing to design limits could be viewed as careless. Careless maybe isn't really the right word either. Maybe just less than through? My view is that testing to those limits would validate that the builder hasn't made a mistake or deviation that erodes an engineered safety factor.
Any aircraft structure that is known to have been exposed to loads higher than limit load (whether during testing or inadvertently in flight) should not be used for flight without some very detailed inspection, and even then I would be very suspicious regarding its suitability for flight, so the answer to your question is an emphatic no.This is a really strong point. It sparks the question whether Van's considered the material that underwent their testing to still be airworthy. That said when load testing structures to validate design stiffness we don't need to go to the limits. I would only go to a limit on the way to an intentional discovery of ultimate load (breaking it which you want to avoid). Since our artificial loads won't match actual use loading it wouldn't be prudent to apply a full design load. Better to validate at some fraction but again you have to have the expected metrics in hand before you get underway. If Van's had been using strain gauges, then that would be a part of finding that sought after repeatability or something that shows you a deviation (weakness).
It's good food for thought. There has to be a Non-Destructive testing scheme to scratch this itch. Probably a lot more work to get there properly than it initially seems. But here in our Experimental Category there's goodness in trying our own things in a safe manner. I personally would follow the crowd here and inspect for plans compliance and signs of problems and call that done. One could go as far as pulling and inspecting some bolts, even magnaflux them and do some die testing of the aluminum attach points to check that block but for an airframe that hasn't been pulling the aerobatic Gs or showing signs of corrosion or poor craftsmanship in those areas that's probably in the overkill dept.
Right, 2% is good enough to fly. So the options are to assume the build is good enough to have some margin and risk finding your wrong during an inadvertent excursion? Or test to verify in a controlled situation?How so? What if a builder error had cut the margin to 10%, or 5%, or 2%............what happens then to the engineered safety margin?
Generally speaking engineering safety factors are usually 1.5 which is why I think the 6G and 9G testing was done for the aerobatic model. Every design is engineered to certain limits, sometimes engineers use a safety factor of 2.0 or 1.25 depending on the application.How so? What if a builder error had cut the margin to 10%, or 5%, or 2%............what happens then to the engineered safety margin?
You should also know with your background that eventually the design and validation of materials is “good enough.” Even a certified Extra 300 can’t go through all of these tests on every single iteration built or it would be unuptanium at a gold plated cost.Some context for where I'm coming from - I'm a design engineer. I've designed mechanical systems for over a decade that are used to manufacture parts in high-volume manufacturing. Without boring anyone with all that entails, I'll enumerate some things that sometimes come up during ramping from prototype to mass production.
I get what some of you are saying about trusting the engineering design and visually inspecting the build. But the manufacturing experience I have is screaming at me not to trust it and to do my own testing. I realize there isn't an easy answer, and at some point, I have to trust the builder. I appreciate all the comments and feedback. You all have given me much food for thought.
- Material input variability. Although the design may be sound and initial prototype testing checks out, when ramping to volume production, material quality deviations can sometimes cause unexpected issues that are not captured by the original design, because the original design assumes a certain range of material properties during manufacturing. There have been instances where fraudulent materials were used (Boeing has fallen victim to this in their engine fan blades). There are many other examples of fraudulent materials entering the supply chain. So, despite the fact that an RV may have been built perfectly to plans, if some of the materials used to build that plane were not manufactured to the design specifications, it would be impossible to detect via a build inspection.
- Process control. Manufacturing inherently involves process variability. In my industry, we validate the integrity of manufacturing processes with statistic-based inspections throughtout the manufacturing process. This allows deviations to be caught and rectified early in the build process. It is impossible to verify whether a bolt was torqued to spec by visual inspection. Since applied torque of fasteners is an inherent facet of the integrity of a structure, absent process control, the only way to validate the integrity of a structure would be to conduct a non-destructive load test.
Some parts of the world require the aircraft to be taken to its limits before it’s cleared for aerobatics.Depends on the desired level of testing. Testing to yield or failure is destructive so yea, don't fly it. The OP seemed to just want to validate design limits. So properly loading the airframe with weights to +6g and -3g on the ground would be no different than doing it with flight testing. It would only be destructive if the assembly was incorrect, thus failing the testing. Certainly a safer way to test than in the sky.
It might be worth looking at the accident data to get an understanding of where the real risks are. Offhand I would say that probably more RV-7s doing aerobatics have come to grief from exceeding speed limits or just plain hitting the ground, rather than from pulling the wings off.
I'm not an engineer but I've fixed enough of their errors in my career to know how their taught to think hahaha. Mburch makes a great point, but idk if statistical analysis is an engineers favorite math. The most efficient way to perform the testing would be to put a parachute on and fly it to the desired limits. That's what test pilots do. But I also understand efficiency and engineers don't go together . (To be clear I'm just teasing with the engineer comments. I have had to repair their mistakes in my career, But I've also literally had their designs save my life more than once when I've made mistakes. Much respect brother!)Some context for where I'm coming from - I'm a design engineer. I've designed mechanical systems for over a decade that are used to manufacture parts in high-volume manufacturing. Without boring anyone with all that entails, I'll enumerate some things that sometimes come up during ramping from prototype to mass production.
That's exactly what I was suggesting and what I intend to do if I ever build one.Some parts of the world require the aircraft to be taken to its limits before it’s cleared for aerobatics.
I seem to remember that Flightchops had to take his RV-14 to the limits. And taking an aircraft to Vne is something that’s done in flight tests quite regularly
