22 iS Fuselage question
Rob H
Page 22iS/U-05, Step 1
I want to understand exactly where to scuff. 1) Is it only where tank sealant is called for in Steps 4 & 5? Or will there be sealant applied to the remainder of the firewall edges in another section?
2) Also, since I?ve painted F-01272-1 and F-01217-L & R, should I assume I?ll need to remove the paint where they mate to the firewall so that tank sealant adheres? I?m not painting the firewall.
3) Is the sealant there just to protect against heat, fumes, fire, moisture etc? I don?t think it was called for in the old fuselage kit. Thanks Rob
Thanks Joe, I?m sure with a fire, the sealant would be low on the worry list. Not really the question. Maybe someone could respond who?s built the new iS fuselage kit. I?m wanting to know if there?s sealant just between the two ribs and on the top flange of the firewall like it describes in this section? Or, if more sealant is applied in a later section around the remaining edge? I don?t want to scuff and clean more than necessary.
I just do what the book tells me to do. I know the other edges get sealed with tank sealant (not sure why its tank sealant and not firewall sealant). I'm not sure why the entire bottom joint isn't sealed..and its only the center.
My guess is that and moisture on the firewall will travel down.. hit the two stiffeners..and be channeled to the center part of the firewall where it would seep inside the center channel (between pilot and copilot).
The entire perimeter of the firewall is sealed in a later step, when completing the forward fuselage.
Correct
Just the bottom center is done during assembly because the fwd tunnel is very narrow and sealing is difficult to do after it is assembled.
