iareapilot
I'm New Here
We are to the point of buying our propeller to hang on our IO360A1B6 engine in the 7. Does anyone have experence or thoughts on the 200RV Carbon Fiber Propeller CS vs a Hartzell CS ?
I would like to see the data that support your statement about the performance of the Hartzell Blended Airfoil prop versus the WW 200 RV. I know of no evidence that supports your statement. What is the basis for your statement about performance and efficiency? For sure Hartzell had been around longer.
r
Larry Vetterman did a comparison, both props had similar performance (within 1 mph). Difference, Hartzell prop weighs 19 lbs more, has a lower idle speed (100 rpm), no rpm restriction under 2,700 rpms and cost less.
The only advantage the Whirlwind has is the 19 pound difference...
See his website for the detail report. I have no actual knowledge of either prop, so take it for what it's worth, another opinion...
